Anybody there?! Problems with Sending (2)
Jerry
1,812
Archived from groups: microsoft.public.windowsxp.print_fax (More info?)
Ever since I installed SP2 I have been unable to start Winfax 10
So I thought i'd try Xp Fax. When I first configured it I could send,
got a handshacking screech and then"error unable to send fax" or
something to that effect (I didn't write it down)
I was also unable to"pause" the fax within the console
I rebooted and now when I use the Wizard it goes thru' to the eend and
nothing. No send. Nothing in the monitor. Nothing in the Console
What gives?
Using a standard PCI US Robotics WinModem w/voice. i have broadband
(but obvously tried it not connected). Running XpPro SP2
What gives? Any help appreciated.
Jerry
> What gives?
Learn some patience! This is a peer-to-peer newsgroup, not MS technical
support! You waited less than three-quarters of an hour. Sometimes it takes
days. Someone will answer you in due course, but not if you post every hour!
My great-grandfather was born and raised in Elgin - did he eventually
lose his marbles?
On Fri, 5 Nov 2004 19:40:20 -0000, "Miss Perspicacia Tick"
>lose his marbles?
No I think its you that has lost her marbles - maybe its hereditary.
See below
I guess you must have voted Bush with such tolerance!
Incorrect.
>Someone will answer you in due course, but not if you post every hour!<
But not you, clearly
J
