Question Anyone have a solutions to rgb fans unsyncing when pc restarts?
FluffyTheCat.
hi all,
Everytime I restart my computer, my RGB Gamdias fans go back to the default RGB cycle instead of staying synced to the motherboard and ram (Have an aorus z390 master and g.skill trident rgb).
1: When I plug the fan controller into the motherboard while the pc is on, it syncs fine but as soon as a restart the computer and turn it back on, the sync is no more.
2: what are you suggesting I put into the startup folder... RGB fusion?
Yes put RGB Fusion in the start up folder. I have it myself and it doesn't put itself there when installing.
I wouldn't gladly connect things to the motherboard when the pc is running. If you by accident short pins or otherwise could you well be in trouble.
