Anyone know about PPI (pores per inch) and what PPI is good air flow?
durangod
86
Hi,
I am wanting to make some custom air filters for my case intake fans, i dont like the pantyhose idea. But i found some black foam air filter sheets on ebay and it says they are 60 PPI but i dont know if that is too restrictive for fan air flow or not.
I did find this much about PPI - The standard is from 10 to 80 PPI where type 10 has large cells and is rather open, whereas PPI 80 has small cells, is more dense, and has a lower air flow. But that still does not tell me is 10 like no air filter and 80 like chocking.
here is what i am looking at:
http://www.ebay.com/itm/191624818206?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
As you said already - Low PPI = More Airflow, but more dust.
High PPI - Less airflow and more dust.
I say the best would be to go for around the middle, so good airflow and good dust protection, if you know what I mean by this anyway.
If you're not sure, a good choice is to get the good parts of one things and put it with the good parts of the other, hence the middle.
hi thanks, yeah the seller told me that after he thought about the application of it, he said the 40PPI would be better. So i will be testing it and if it works ill let everyone know here.
