[SOLVED] Anyone know of a reasonably priced large (full ATX) case (less than £100, preferably less than £80)
David_647
34
Just like the thread title says, I'm looking to upgrade my case as my Salman Z9 plus is quite cramped, the I/O shield has problems fitting and not all the screw headers line up with the.motherboard properly, so the motherboard only has 3 screws (yeah, I know) holding it as such I.Have the case on its side for now and it gets rather dusty due to all the fact that it's basically open on the side (honeycomb metal mesh), I'll be looking to put a closed system water cooler in the next case.
I have an MSI B450 motherboard and an RX450 GPU, but I would really like a spacious case.
A nice clear tempered glass side would be a bonus, but not a requirement, though a see through case side would be a definite want.
Decent looks, cooling, cable management and modularity as well as a spacious, large case would be what I'm after. Built in dust filters would be a bonus.
I know I'm asking for quite a lot on a rather limited budget but the case wouldn't have to be new, I'm always open to looking for used cases on eBay.
So if you've any suggestions I would love to hear them.
Thanks.
Wasn't sure to put the thread in components or systems, I went with components as a case is a component that holds your system together.
@SR-71 Blackbird
Thanks. I had been looking at that case. It seems like it's the part. CCL does some cheap full cases with nice RGB systems and lots of fans though they seem to be quite poorly constructed (e.g. A bunch of fans up front with a 1cm clearance between the glass and fans on the front panel) honestly the.cheaper the better (which is why I'm very checking out the second hand market) and maybe bid sniping a case on eBay (that may have cost >£100 for £40-70. I missed a really nice coolermaster one though eBay seems to always have second hand cases and I don't.mind superficial damage, so long as the case isn't bent.
If anyone has a great case that's a couple of years old, let me know and I can always see if that's selling second hand somewhere.
Otherwise I may go for the phanteks one, but I'm not in any major hurry. I plan to get a case, a water cooler (closed system) and a fast M.2 SSD (probably 512GB) at the same time. I just got a new.motherboard, CPU and RAM recently so I'm really trying to get my money's worth with a case.
