I want to get one of the best video cards for my system. I can afford up to $100-200, but I cannot afford to keep buying ones till I find one that works. Better safe than sorry.
My system... HP Pavilion Media Center
--HP Pavilion m7550n
--AMD Athlon 64x2 5000+ 2.60GHz Dual core processor bi-processor
-- 400gb/go SATA HDD
--4 gigs of ddr2 ram 800mhz
--NVIDIA GeForce 6150 LE graphics card
This system has been altered 3 times.
The motherboard fried out, it was replaced with a Gigayte S-series motherboard. Specifically M61PME-S2p (version 1).
The power supply blew and was replaced by a 400 watt power supply.
I upgraded from 2 gigs of ram to 4 gigs which is at its max.
Also, I also replaced the 16" crt monitor about 1 month ago with a ASUS 23" led monitor (specifically ASUS MS238H).
The system is running vista in 32 bit. I was told that vista can only use 3.3 gigs of ram and for that reason, getting a video card with more than 512megs of ram would be a waste.
I also read that ATI cards do not work with my system, so maybe its best to stick with NVIDIA?
Also, I am quite sure that my motherboard has only a PCIe 1.0 , so I do not know if it will be able to run a PCIe 2.0 card.
Would also prefer to get a card with HDMI as my new monitor has that type of connection.
The current card has no fan, so do not know if my system can run a card with a fan.
Also, you have to pretend I am stupid if anyone cares to offer advice.
Thanks for your time.
