Question Anyone use Samsung Smart Monitor M7?
Vayne77
86
I will use it on my room...not that big, that's why I search for 32 inch....at first I check for TV, generally the 4k is only for 43 inch.
I found Samsung Smart Monitor M7 which is 4K 32 inch monitor but has Smart TV feature
I will use it for watching Netflix and other plus for PS5. Anyone have used this monitor and satisfied with it?
Lutfij
Can you elaborate on what you mean by other in between Netflix and PS5? At the time of writing, I'd state that you look into a TV as opposed to a monitor unless you intend to hook up a PC to the panel you intend to purchase.
Vayne77
86
Other like prime, Disney+, etc
Is there a good 4k 32 inch TV?
