Question Anyone using Aigo DarkFlash Shadow Air Cooler?
sagor1
56
Will it decrease my i3 8100 temperature bellow 60'c during gaming?
My cpu temp idle 45-53°c during gaming 68-75°C.
It's feel too hot i can't even sit infront of it & using my pc comfortably.😥
Btw another problem is i bought a antec prizm 120m argb fan from someone i know.He got this fan with antec da601 case.
My case is Antec dp501 & mobo is Asroc B365m Phantom Gaming 4.
I plug the fan pwm header to my mobo chassis fan port.
But when i plug it with my casing controller.....casing light stuck to a single color & fan light not work & neither the casing light mode button work.
I also tried it with my mobo argb port.Not work.
What to do?
sagor1
56
You might want to post where you're located and what your ambient air temps are...? Did you try connecting only off the ARGB header located next to the DIMM's?
I am from Bangladesh.I can't tell my room temps but my area temp is 33°C.Yes i tried it with my motherboard argb port.
Also i saw the Aigo darkflash shadow on amazon...they mention this.
As far as i know it's come with only argb header.The 4pin they mentioned it could be the pwm header.
Should i also i try with my antec fan pwm header connect it with rgb port?
