Anyone using an IDE Controller card with A7N8X-E delux?
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
When I attach a HD to the card, the system won't boot. HD is detected
OK. A floppy for example, makes the usual noises and motions as it
prepares to boot but always stops short of actually booting.
If I attach a CD-ROM drive, the system boots OK.
Have tried two types of controller card so far - same result.
If anyone has had more joy, please tell me what you are using
thanx
jd
In article <41pdh09mjuvs4apou9oqdg8nkk4n37u5tg@4ax.com>,
jdean@nowhere.soon, Jimmy Dean says...
> thanx
> jd
What kind of card is it? I have a Silicon card and when I attached an
extra drive it assigned it as the primary (IDE0) drive, hence, looking
for boot files. When I removed I got my OS back. Since than all I have
is attached is CD Roms.
You may want to check the assignement order of the drive......
"Jimmy Dean" <jdean@nowhere.soon> wrote in message
news:41pdh09mjuvs4apou9oqdg8nkk4n37u5tg@4ax.com...
> thanx
> jd
I'm using an A7N8X Dlx and the last BIOS update added the
choice of booting from SCSI or SATA. I would check in the
BIOS if you haven't and set it to scsi.
Jim M
I'm using a Promise Ultra 100 TX2 in my A7N8X-E Deluxe, BIOS version 1008.
I have a HD and a Zip drive attached. No problems whatsover. Have you
double checked your HD jumper settings?
> thanx
> jd
This can be due to your BIOS settings.
In the BIOS have you set the first hard drive (HDD-0 - or SCSI if your drive
is connected to SATA) as your boot drive ?
Your floppy drive, if you wish to boot from it ?
"Jimmy Dean" <jdean@nowhere.soon> a écrit dans le message de
> thanx
> jd
In article <GSCRc.14024$cK.10693@newsread2.news.pas.earthlink.net>,
markdpend@spambegone.aol.com, mdp says...
One of the reasons why I bought the promise card (I have the same
model), it works correctly and assignes HD order properly. I can almost
bet he/she bought a Sil card...... :0)
"JBM" <jmanning95@hotmail.com> a écrit dans le message de
news:Ob2dnQC2WPcVd4vcRVn-jQ@comcast.com...
> > thanx
> > jd
> Jim M
The E-DeLuxe BIOS only gives a choice of HDD-x or SCSI (SATA).
I have:
A7N8X-E Deluxe
Promisse FastTrack100 with 2x 120GB Samsung @ RAID1 as system drive
120GB Samsung @ onboard Controller as temp drive
SATA disabled
No Problem to boot from the Promise!
Just set the BIOS to boot SCSI.
(everything not in the chipset is "SCSI" for the BIOS)
my BOOT order:
first drive: floppy
second drive: CD-ROM
third drive: SCSI
boot other: disabled
read you!
KALLE
see http://www.jump.net/~lcs/kalle/ for T2P4 and some other outdated information.
On Mon, 09 Aug 2004 12:43:34 +1000, Jimmy Dean <jdean@nowhere.soon>
>thanx
>jd
Thanx to all the responses. I should clarify that I wish to boot from
a parallel ATA HD attached to the on-board Primary IDE controller.
The IDE controller card was for attaching a couple extra HDs (I have 8
in all, 4x HDs, and 3x CD/DVD drives). So I do not wish to boot from
these - if I did I presume I would set the boot order to be SCSI
first.
Yes, the two controllers I have tried have both been Silicon brand.
I would have liked to get the Promise e.g. ATA 100 TX2, but as it is
much more expensive, it would have had to be specially ordered.
Anyway it anyone is interested, this is the final config I came up
with: W = Western Digital 8 MB (JB or JD, pATA or SATA resp.).
I wasn't too fussed on using the legacy to SATA power splitter which
came in the A7N8X-E dlx pack (have had bad experiences with splitters
and HDs in the past), but then I found WD HDs have both legacy and
SATA power connectors!
HD W80B as Primary IDE Master (SYSTEM, APPS, DATA, DOWN partitions)
HD W160A as Primary IDE Slave (BACKUP drive)
HD WS120A as SATA1 (PROCESS and ARCHIVE partitions)
HD WS120A as SATA2 (DVDRIP drive)
LiteOn XJ-HD166S 16x DVD-ROM as Secondary IDE Master
HD W120A as removeable backup hard-disk (REM_HD drive)
Pioneer DVR-A05 as IDE Controller card Primary Master
LiteOn LTR-48125S CD-RW as IDE Controller card Primary Slave
The CD/DVD burners seem to work OK on the cheapie controller card,
though I have yet to test them thoroughly. Slow to detect in POST -
probably adds 10-15 s to the bootup time.
cheers
jd
In article <5cfjh0daiu20vs7sghhp46enc3b2qmurqe@4ax.com>,
> first.
Good luck than because I have been back & forth with Siig about the same
issue you are discussing when I bought mine, whereas the siig makes any
HD connected to it the "Primary" IDE0 drive. IDE0 meaning the "boot
drive".....I bet if you attach your HD W80B to the primary on the Siig
your system will boot.
If this is the case than I do not know how to make the Siig an "Extra"
IDE controller, which is what the Promise does and does not take over
your drive order. Maybe disabling the BIOS on the Sil card, I'm not sure
as I never got that far (to frustrated) I gave up after Siig could not
help me, so since than I've attached a CD, DVD burner, & a DVD player (3
items) to the Siig and all works perfect & fast.
BTW: I have 6 HD's / 2 burners / a DVD Player / and a CD reader attached
to my one machine with 2 PCI controllers cards installed. Believe me
I've been through the ringer with this machine but it works perfect.
Bottom line as to what I'm saying: I am not able to attach EXTRA HD's to
the Siig period!
> cheers
> jd
On Mon, 09 Aug 2004 04:14:30 GMT, "mdp" <markdpend@spambegone.aol.com>
Yes, no problem there
jd
>the Siig period!
That exactly agrees with my experience to date: Siig OK with CD/DVD,
hopeless with HDs
One other responder said that had no probs with a Promise ATA100 TX2
controller and HDs.
As usual, it's price,price,price...
Thanx for your input
jd
