Anyone with ASUS Z9PE-D8 ws. Need Help
marchitect
7
In my quest to solve my Q-code error. I'm asking for anyone with this board to please let me know what code your motherboard is showing. Preferably if you have a Windows 7 machine. I'm trying to establish if my code 22 is indeed the error I think it is. If other boards are displaying a similar code I will relay that info to the ASUS tech support people I am dealing with.
Thank you anyone that participates.
I really appreciate it.
It's interesting that on one posts the Q-Codes their board is displaying but rather tries to come up with answers that are vague. It turns out that you should be showing 22 if all is good and running Windows 7.
Anyway, I received an answer from ASUS today.
It turns out that Q-Code 22 is totally normal and yes it does relate to Windows 7.
Here is the direct response I received from the Asus team:
About Q-code stopped on "22", it's a normal behavior. Because Q-code only help to identify the process during POST, but not including entering OS, that means Q-code debug process already finished when system prepare to enter OS. And the last number it shown will depend on BIOS ME (Intel Management Engine). Different MB or BIOS may contain different behavior of ME, that's why some MB's post code will stop at "00", some stop at "22" or "AE". And in Z9PE-D8 WS, the ME last step will stop at "22" and prepare to enter OS.
You can or have customer to download video our Team tested for your reference. You can see the Q-code stopped on “22” after loading OS.
https://www.asuswebstorage.com/navigate/s/964182FA9D74494CB2E276A9FC324B09Y
