Anything wrong with this system build?
Apr 12, 2018
27
Is there anything I should change about my new PC I want to get? Also,if I get the AMD Ryzen 2200G will I need to get a graphics card with that build? I will not be doing any hardcore gaming.
CPU: Ryzen 3 2200G with Vega Graphics
GPU: No graphics card as on budget and the CPU above has Vega.
RAM: 2x16GB DDR4 Corsair Vengance
HDD: 5TB SATA
PSU: Corsair 450W
CPU COOLER: AMD Wraith Stealth
THERMAL PASTE: Cooler Master Mastergel Maker Thermal Compound
LED LIGHTING: 50cm RGB strip.
EXTRA CASE FANS: 2 x 120mm.
CASE: NZXT Phantom 240
I remember your other thread , I did foeget to reply on there.
You have a £800 budget If I remember right ??
Whats this budget for??
Is it just the tower , or do you need peripherals ?? Keyboard, Mouse , OS (although win 10 can be used free of charge) , monitor ??
Either way , what you're actually throwing together there is honestly badly thought out.
The board is low end , you dont need 32gb ram Im positive , the 5tb seagate drives are 5400rpm, slow clunky for os use & I dount you will ever need that space.
Even if you do for the same money you can get a 240-250gb ssd for os & app installs & a secondary 3tb 7200rpm drive which is going to be far better performance & reliability wise.
Does this have to be a prebuild ??
If you're willing to build yourself you can get much much more for your money!!
