Question AOC 2590G4 - Strange ghosting issue.
Ljac95
Commendable
May 21, 2017
25
This monitor is a 144hz Freesync enabled panel with G sync enabled, for some reason 2/3 times when I launch any game there will be this severe level of ghosting. For example when you move the mouse across the screen there will be a visible trace of where I moved it. I have a work around for it, where if I simply turn the monitor off and on again or try and switch to another display output (one that is not connected) and then let it switch back the issue fixes itself.
What I have been trying to figure out is what causes it in the first place and if there is merely some setting I need to adjust, please let me know if anyone has experienced this before or determined a cause.
Thanks in advance.
My Specs are:
i76700k @ 4.00Ghz
GTX 1080ti
16GB Ram @ 3000mhz
