Hello,
I recently brought a PC, i use a dual monitor display. The Samsung monitor runs perfectly, it uses the DVI to VGA cable. Where as the Primary monitor, the AOC monitor runs directly via VGA.
The connection with the AOC is ok but annoying. Basically it runs fine then randomly the screen would go fuzzy and the icons would start to shake almost.
What can i do to fix this?
Thanks,
keemann
Thanks,
keemann
