AOC Monitor Setting Issue
ImNotTechSavvy
Commendable
Apr 13, 2016
7
Hello,
I bought an AOC Monitor for my Xbox 360 as i wanted better graphics (i was using an old tv beforehand) I got the adapter and it worked perfectly for some time, 4 months later I can no longer use the monitor due to this issue. It has the settings DVI & D-SUB, my Xbox uses the D-SUB however it wont switch off of DVI, i've sat in my room for extended periods of time switching it from DVI to D-SUB only for it to not switch and stay on DVI, even after several shutdowns i still experience the same issue.
Any help will be most welcome
Thanks
The HDMI hooks into the back of my xbox and the vga goes to the D-SUB cable that hooks into the monitor (d-sub/ dvi are the selections in the menu)
I got it exchanged with AOC, thank you for your assistance (insert thumbs up emoji here)
