[SOLVED] Aorus 360mm AIO Cooler
Mar 8, 2020
13
So I have this cooler installed, booted it up and it's not detecting what cpu I'm using or displaying the temp.
Tried getting on to the Aorus website to download the Aorus Engine but the download link isn't working.
Can anyeone help with this?
Ok, so the problem is you cannot complete the download?
From your description, it sounds like Gigabyte's servers are the problem...
I just went to try, and most of the regions are fine (Asia, CA, US) but the EU link gets stuck.
I'm assuming then, that you're using the EU link?
I don't believe there's going to be any difference in the software obtained via each link, they should just be regional servers -- and something is wrong with the EU.
Just use the download links from another region.
How would the AIO detect the CPU you're using?
I'd assume software would link it all together, and would probably be required to display CPU temps (opposed to fluid temps, which it could possibly do stand-alone).
I haven't seen much on this particular AIO though, so can't say for sure.
Assuming you're downloading from here?
https://www.aorus.com/product-detail.php?p=1306#pd_download
Links work fine for me.
The cooler come with some pins that are attached to the motherboard and the software to download let's you configure it and set it all up. But whenever I go download it the download completes like 7.0mb then just shoots to a 3/4 day download for a 100mb download.
I mean my internet isn't an issue i know that for a fact.
