[SOLVED] Aorus engine OC stuck
Jun 15, 2020
Hey,
I recently bought a gigabyte 1650 super windforce OC and decided to use Aorus engine to auto scan it and apply an OC.
My base clocks listed on the card are 1755mhz core and 12000mhz memory. https://www.gigabyte.com/ca/Graphics-Card/GV-N165SWF2OC-4GD/sp#sp
After running the auto scan it appears to have set my speeds to 1980mhz core and 6000mhz memory according to HWmonitor.
I wasnt happy with it apparently dropping my memory clock by 50% so I decided to try and reset it to default speeds and manually adjust it myself. The issue is that when I click default and apply nothing seems to happen. HWmonitor still says 1980mhz core and 6000mhz memory even after clearing the min/max values. To try and fix this I uninstalled Aorus engine and used DDU to uninstall my drivers and reinstall them. Afterwards I ran HWmonitor again but it still gives me the same numbers. From here I decided to download MSI Afterburner and see if it would help but MSI Afterburner shows my settings as being at 1755 core clock(Doesnt show what memory clock is set to). When I run rivatuner which comes with MSI Afterburner it gives me the same as HWmonitor, 1980mhz core and 6000mhz memory and when adjusting the clock speeds it confirms that, adding +50 brings me to 2030mhz core and +50 on memory brings me to 6050mhz memory.
I can set it to 1755mhz core by setting it to -225 on the core clock settings but there seems to be no way to get my memory clock back to 12000mhz. So I am currently at a loss and looking for any advice, if anything I just want to set my card to the default clocks it arrived with but I cant figure out how.
