[SOLVED] Aorus Extreame- no front audio header?
DRagor
Illustrious
This is ridiculous, I can't believe they could not connect front ports in $900 motherboard. And it has issue with powering computer on.
Well, likely they build it for other purposes that don't require high quality sound options. Still, most monitors allow to connect headphones to them so the lost of front panel audio is not necessarily big deal.
As for powering on, DOA parts can happen at any price segment. Or maybe you connected something wrong.
DRagor
Illustrious
The list of internal connectors include front panel header so I suppose it does use front audio as all motherboards. As for back connectors it indeed has only Line out and Mic ports. I guess with all those USB ports they simply did not have space on back panel for more audio ports.
Astralv
1,906
9
19,965
79
Actually I checked the mobo manual and indeed the front panel connector does not allow for front panel audio devices. Looks like this board sound options are severely limited.
DRagor
Illustrious
