[SOLVED] aorus fusion help
Omer_5
Commendable
Mar 30, 2016
41
So I just got the Aorus ac300w with aorus mb and cooling.
and I wanted to know if there is a preset or something like that, that can sync all of them together, I tried Fusion but it's not sync them all.
Any ideas?
You can set all of them to be the same color, but if you're going for rainbow you're not going to able to sync them using the fusion tool. You can try seperate RBG softwares if any are compatible with your devices.
Do you know any ?
my spec - 240GB SSDNOW A1000 (PCIe NVMe™ Gen 3.0 x2) M.2 2280 - 1500/800MB/s - SA1000M8/240G
Prizm KIT 3x120mm RGB fan, 2x Strips, Controller
AORUS CPU Cooler with RGB fusion – 16.7M Customizable Color Lighting - Dual 120mm 2 ball bearing (PWM) fans - 3*10mm high performance copper heat-pipes - Heat-Pipe direct touch technology - Intel Socket LGA 2066, 2011, 1366, 1156, 1155, 1151, 1150, 775 - AMD Socket FM2 , FM2, FM1, AM4, AM3 , AM3, AM2 , AM2, 939, 754
2TB - 3.5 inch -SATA3 6Gb/s - 7200rpm - 256MB Cache - BarraCuda
Aorus z390 elite
16GB (2x8GB) 2933MHz DDR4 CL15 DIMM - RGB - HyperX XMP Predator Series - HX429C15PB3AK2/16
AC300W AORUS ATX Mid-tower PC Case - RGB Fusion-16.7M Customizable RGB Lighting - HDMI and USB Type-C I/O Panel - NPS
650W Neo Eco Modular - With New PC Only - 80Plus Bronze, 120mm - Brown Box
