AORUS GeForce® GTX 1080 Ti 11G vs MSI GeForce GTX 1080 Ti ARMOR 11G OC
m2net
42
Hello guys,
I have the opportunity to buy one of this 2 cards, for GAMING only, please help me to choose.
( let's not care about price or monitor,.. )
AORUS GeForce® GTX 1080 Ti or MSI GeForce GTX 1080 Ti ARMOR 11G OC
Thank you
AORUS is the standard edition, not Xtreme, still same choice ?
sorry for mistake and thanks for answering
I have a method to pick between equally performing products.
Go to Newegg and find the candidates.
Filter on the reviews by verified buyers.
Then look at what percent of the reviews have zero or one eggs indicating some sort of a problem.
In particular, look at the reasons for a bad review. Some are not very valid, so exclude those.
By that method, the gigabyte card should be better.
A quick scan tells me that the EVGA cards are likely to be better than either of your choices:
Here is one:
https://www.newegg.com/Product/Product.aspx?Item=N82E16814487336
Thanks for the trick, i tried it and the Gigabyte seems better, my only options here are the Gigabyte and MSI.
