AORUS GeForce GTX 1070 8G build problems
wiwolobrer
6
hello guys
past week bougth a new computer
open the box i plug gpu hdmi to a tv sony 46 inch monitor 1920x1080
this is https://www.cnet.com/products/sony-bravia-kdl-60ex720/review/
start good
i bougth the pc in online store mount custom pc and is tested by himselfs ihad 2years guaranty
directx is intalled and redistruble packs
i try asseto corsa benchmark and and was running good at 130 fps or something maxed out 1920x1080 so cool i istall bluetoth mouse keyboard
next day i open internet explorer and the screen start whit green or blue like boxes
and kind of flashing
then i try asseto corsa benchmark again and ihad a black screen
i made a video for you guys:https://www.youtube.com/watch?v=vZwokorXnQI&feature=youtu.be
go to stock fsx recenly instaled and pick a cessna go to airport and the game look terribol like a rainbow of colors then crash saying update drivers
minecraft runs flawless
ark for example, screen with weird boxes and crash saying update driver
i put 382.33 downloade from nvidia site i use guru3d tool to unnistall from safe mode and the same hapened
noticed in safe mode screen was flashing too
CPU: Intel i7 7700K 4.5Ghz Quad Core con HT
- RAM: 16Gb (2x8Gb) Corsair Vengeance LPX 2400 DDR4 CL14
- HDD: Western Digital Blue 1Tb 64Mb Cache 7200RPM
- box: Cougar MX310
- Placa Base: Asus Z270-P Prime
-Corsair VS 650W 80+ Bronze
- SSD: SSD Western Digital Green 120Gb M.2 550Mb-s
- gpu: Gigabyte GTX 1070 G1 OC 8Gb GDDR5
- so: Windows 10 Home 64Bit
maybe is the monitor,defect of new gpu,power suply,drivers ,the cable hdmi im uising im not sure 1.4 but am not sure ,maybe windows 10 updates viruses
want try dvi but my monitor dont have only rgb
what should i do? help my guys
using openhardware monitor
gpu about 37 C
cpu cores max to 65 C
