I just built a new Gaming PC. I have a Gigabyte Geforce RTX 2070 Super. On the driver CD there is a program called Aorus Engine you can install. Should I install it? What is it?
In retrospect, you should install drivers that are found off the GPU's manufacturer's support page. That way you have the latest there is. The drivers on the disk are for getting your platform up and running but not at optimal performance.
