I just installed my first AIO and the radiator is loud as hell. It's a constant electrical motor whirring sound (not air bubbles sound) that fluctates from mildly annoying to super loud whenever the cpu temperature spikes (booting pc, opening a program, etc). It seemed fine when I first installed it, but as soon as I ran Aorus Engine after installing the software it got very loud. I found this reddit post which details 100% the same exact problem I have, every single word in the whole thread is spot on (even the aorus engine part and rgb fusion not changing fan color), but there is no solution mentioned. I don't think its the fans that are the problem, it sounds like its coming directly from the radiator itself. The radiator is correctly top mounted with the pump and tubes below to prevent air bubbles get trapped. Any idea what is happening?
