Hello.
Some days ago after a boot i noticed that my pump fin was not spining at all after the post. It spinned for a few seconds befor post but then it stopped. I got in the bios settings and I noticed that the cpu temperature was read at -55C. I got in smartfan 5 and i got it to work only by setting the fan mode to PWM instead of automatic. I also set it to full speed. I have my pump connected to cpu_opt port. HWinfo64 and Ryzen master can succesfully show me the cpu temps. Other problems i faces are the foolowing.
ryzen 3800x
Aorus x570 ultra
trident Z rgb 2x8gb cas 16 3600 mghz samsung die
rm750x by corsair
cougar helor 240 AIO cooler
rog strix gtx 1080
Any suggestions would be really helpful
screenshot of my mobo cpu temp
http://rag0n.tplinkdns.com/index.php/s/fPRHCenS5rtaNDb
- Sometimes my pc doesn't post and it is stuck in cpu check led untill I completely kill the power from the psu for a few seconds and then i get it back on. Then it posts ok.
- 2 times when i booted into windows and tried to launch ryzen master i got a failed to initialize error kindly reinstall and after the second reinstall im now unable to get it to work.
ryzen 3800x
Aorus x570 ultra
rm750x by corsair
rog strix gtx 1080
