The Aorus Z370 Ultra will have no problems supporting the H55 AIO from Corsair...In fact all motherboards will support the H55 and provided your case has space for it, ussually the rear 120mm fan is where you place the H55, then no issues...Nearly all cases tend to have space for a rear mounted 120mm AIO, so should be no issues.
You will get a Intel 115x bracket with the H55 that will allow you to connect it to your motherboard no issues...
