Hello and greeting from Bulgaria !
Recently I bought
Z490 Aorus elite ac MB
I also have 6 pcs ot Zalman ZM-RFD120A fans with 3 pin connectors.
Today I bought a Cooler Master Masterfan ARGB and PWM hub, but cant make it work... 🙁
I try several different connections but whe I plug some fan in this hub they all work at 100%
I try to change different settings in BIOS but nothing...
Now i Connected the hub 4pins to my CPU Opt , connect sata to hub and 3 fans into the hub.
I also tryed to connect the hub to cpu, cpu cooler to the hub and other 3 fans also in the hub. The cpu cooler is with 4 pins and works with arround 1000-1100 rpms, but other 3 fans spins with 1400 rpms and it is very loud...
So I think that this hub works only with 4pins fans or im wrong ?
Can you please share your opinions and told me is it possible to use properly this hub with my setup?
Thank you in advance
Kamen Todorov !
https://www.gigabyte.com/Motherboard/Z490-AORUS-ELITE-AC-rev-10
Recently I bought
Kamen Todorov !
