All UPS will generate some amount of noise while running from battery due to the strong magnetic fields inside their transformer. How loud that will be depends on how tight the windings are, how stiff the iron/ferrite core is, whether the windings have been coated in additional enamel or other material to lock them in place, etc.
Some buzz is inevitable and some UPS are louder than others, you'd need to describe/qualify what 'loud' means for you in this context. Personally, I'd describe my loudest UPS as merely distinctively audible over typical ambient noise, perhaps a bit louder than whispers.
