[SOLVED] APC_INDEX_MISMATCH with Maximum VII Hero
Feb 10, 2019
I have been dealing with a APC DISMATCH BSOD and I don't know what to do to solve it.
Here are the details from WhoCrashed
Computer name: Robert-PC
Windows version: Windows 10 , 10.0, build: 17763
Windows dir: C:\Windows
Hardware: All Series, ASUS, ASUSTeK COMPUTER INC., MAXIMUS VII HERO
CPU: GenuineIntel Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz Intel586, level: 6
8 logical processors, active mask: 255
RAM: 17118691328 bytes (15.9GB)
Crash dumps are enabled on your computer.
Crash dump directories:
C:\Windows
C:\Windows\Minidump
On Sun 2/10/2019 2:13:36 AM your computer crashed or a problem was reported
crash dump file: C:\Windows\Minidump\021019-45546-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x1B1B40)
Bugcheck code: 0x1 (0x77811CBC, 0x0, 0xFFFF, 0xFFFFEB0B3CD41B80)
Error: APC_INDEX_MISMATCH
file path: C:\Windows\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This indicates that there has been a mismatch in the APC state index.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
A software/driver related issue, I'd say. Since not aware of the drivers/software you're using... hard to say. Try reinstalling Windows, only the needed drivers and testing.
