Hi all,
I have an Apeman dash cam I purchased on Amazon 3 years ago, the cable which came with it recently broke and I would like to replace it. I'm pretty sure the model number is C450. The cable that came with it is connected/glued to the car charger part and the car charger has one slot for USB, I am attaching pictures so you can see what the plug looks like. I believe it's a mini USB and not a micro. The problem is all the products I see on Amazon have USB on the end and not a car cigarette piece. So first of all, I would like to know if these type of cables work as a replacement and if so, am I supposed to cut the cable where it is connected to the car charger and just use the old cigarette charger with the new cable?
https://www.amazon.com/gp/product/B078LZP132/ref=ox_sc_act_title_2?smid=A32CCO9JZK8JJE&psc=1
Thank you in advance
