I was wondering whether to get an apevia or a bitfenix 200mm fan for my new build, they are the only green led fans that come in the 200mm size so my choices are limited. I want a fan that will provide sufficient green lighting to my case and that will cool quietly and effectively
also, there apear to be three bitfenix fans on newegg, which one is superior?
the fans are as follows:
bitfenix 1:http://www.newegg.com/Product/Product.aspx?Item=N82E16835345051&cm_re=bitfenix_spectre_green_200mm-_-35-345-051-_-Product
bitfenix 2:http://www.newegg.com/Product/Product.aspx?Item=13K-000H-00002&cm_re=bitfenix_spectre_green_200mm-_-13K-000H-00002-_-Product
bitfenix 3:http://www.newegg.com/Product/Product.aspx?Item=N82E16835345015&cm_re=bitfenix_spectre_200mm_green-_-35-345-015-_-Product
apevia:http://www.newegg.com/Product/Product.aspx?Item=N82E16835228029&cm_re=apevia_200mm_green-_-35-228-029-_-Product
