Appropriate RPM for a front 120mm case fan
imapaladin
51
Hello, I'm planning to pick up an Antec Eleven Hundred but I heard it doesn't come with front 120mm fans.
I'm planning to install just 1 but I'm not sure which fan to get.
I'm kind of noise sensitive and I'd prefer a fan that's quieter.
Scythe Ultra Kaze 120MM High Static Pressure Fan 38MM 3000RPM 133.6CFM 45.9DBA
http://www.ncix.com/products/?sku=26744&vpn=DFS123812H-3000&manufacture=Scythe
seems to be the most popular one, but some people say it's a little loud.
On the other hand, this one is quieter(at the same level of rpm I presume) but it only has maximum of 1000RPM.
Is 600-1000 RPM enough for a front fan? Is what people say about Scythe Ultra Kaze being louder true?
I don't want to have a jumbo jet take off in my room 🙁
The only parts that would benefit from the extra fan up front is your HDD/SDD. Try it without a case fan mounted up front and monitor your temps. If your parts get too hot, then consider getting another fan. Great article on fan placement and cooling effect: http://www.bit-tech.net/hardware/2012/02/10/the-big-cooling-investigation/1
Consider getting a fan controller to be able to vary the speed...and noise...of your fans. I use a fan controller with some great Yate Loon fans...QUIET.
Loons 4/$20: http://www.petrastechshop.com/12yalod1cafa.html
Review: http://www.overclock3d.net/reviews/cases_cooling/yate_loon_d12sl-12_120mm_case_fan_review/1
I forgot to link the second fan I mentioned... it's this one.
Antec TrueQuiet Pro 120MM Ultra Silent Case Fan W/ Silicone Mount & Adjustable Switch 10.8-18.8DBA
http://ncix.com/products/?sku=67781&vpn=True%20Quiet%20Pro%20120&manufacture=Antec
I got impatient and just ordered one...lol Not that of a price increase compared to what I've already spent anyway.
In addition to cooling the HDD and SSD, I heard it also helps with the intake of air into the case which improves the airflow and a lot of reviewers recommended that I get one so...can't hurt to have one I guess.
Not to mention I may be doing some OCing on the new 3570k.
