APU A10 7870k slower than a6 3500
Patricio_1
99
I just bought an upgrade, I was gaming with an a6 1.4 and a hd 5450.
I upgraded to this procesator, plus 8gb more ram.
But it works slow, like when you open something like spotify it takes time to open it all.
And for gaming am geting less fps and more stucks.
Sorry for my bad english, what can i do?
Sounds like a motherboard bottleneck but could also be a driver issue.
Check driver's make sure the correct one's are installed and uninstall the incorrect drivers if you have any
also check the reputation of the motherboard with that APU, it may say they are compatable but can it move the data fastenough.
or your hard drive is being hammered all the time, try and have minimal stuff open and defrag ect
Okay, the mother is an f2a88xm-d3h in the box it says amd a lot of times so i think its good.
i just free my ram from 2 to 10 and i get a boost in turning the pc on and navegating.
gonna try the games
