SORRY ABOUT THE LONG POST!
I've been trying to help a good friend of mine fix his problems for over 8 hours....We can't find a solution. His CPU/APU (a10 7800 3.5ghz) is always at 98-100% load, even with nothing open. Nothing sticks out on the Task manager either...Open up skype, and then it says skype 50% cpu, but everything else is at 0 - 2%. (cpu is still at 100% here btw).
Heres a list of things I've tried.
-We've done several scans with malwarebytes and roguekiller in both normal mode and safe mode. It cleaned up a lot of stuff, but still same problem. (Took a lot of time, his hard-drive is nearly full. 30gb free)
--We've ran the SFC command and the DISM command. Nothing.
---Fully updated windows.
----Uninstalled, deleted clean and removed every single AMD software / driver on the computer. Reinstalled Crimson and updated with all the newest drivers.
-----Removed all other anti-virus's on his computer, installed norton.
On the AMD System Monitor app, It shows the cpu at 100% load aswell, with the gpu at 0% load. Even with games and or apps open, the gpu stays at 0%. The integrated graphics go from 1-100% load randomly, even with nothing open.
I'm under-educated on how the AMD dual-graphic stuff works, but I feel like the APU is always under load because its compensating for the GPU, that is doing absolutely nothing. The GPU is enabled, and in working condition.
There was a brief 10 minute period where the CPU went back down to 10-15% with skype and a few youtube videos open, then it randomly spiked again and has been 98-100% since.
I'm open to all suggestions, i'm really completely out of ideas now. Please give feedback.
AMD a10 a7800 @3.5ghz 4 cores.
8 GB standard ddr3 ram
1tb Standard Hard-drive
Radeon R7 240 2gb.
Radeon R7 240 2gb.
