How To APU Laptops Low FPS Problem Solution
Jan 21, 2020
Hi everyone!
I have a AMD A10 9600p laptop and a low fps problem for a long time...
But i found the solution!
I just did three things and now i have a good fps at all games!
1-I turned back to Windows 7 because CPU doesn't good on Windows 10!
2-I installed OEM graphic driver from HP and i change AMD settings for more performance. (Except under Gaming tab, don't touch there!)
3-I changed CPU power management on control panel! (Minimum %75 and Maximum %99)
Now laptop is smoothly!
Why i did that?
Because CPU use GPU's power for more performance! After this settings CPU and GPU working correctly...
Reactions: Diddly
