APU over dedicated GPU for Dual monitor
Bellishot
9
im wanting to set up a dual monitor display, can i do this with an AMD A10 7700K APU alone or will i need to get a dedicated GPU? if i need to get a GPU it will probably be an older one as im trying to build on a budget. also what would the minimum requirements be to run dual monitors?
this is my build at the moment
PCPartPicker part list: http://au.pcpartpicker.com/p/YRqXQ7
CPU: AMD A10-7700K 3.4GHz Quad-Core Processor
Motherboard: ASRock FM2A88X Extreme4+ ATX FM2+ Motherboard
Memory: G.Skill Ripjaws Series 4GB (2 x 2GB) DDR3-1333 Memory
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive
Case: Deepcool TESSERACT BF ATX Mid Tower Case
Power Supply: Antec 500W ATX Power Supply
Optical Drive: LG GH24NSB0 DVD/CD Writer
Operating System: Microsoft Windows 8.1 OEM (64-bit)
thanks in advance guys :)
To quote ASRock:
"Graphics, graphics and even more graphics! You've demanded for more eye candy, so this motherboard supports Triple Monitor. You may choose up to three display interfaces from the rear i/o to connect monitors and use them simultaneously without installing another graphics card"
Yes, you can do up to 3 monitors with your APU. One DVI, VGA, and HDMI.
http://www.asrock.com/mb/AMD/FM2A88X%20Extreme4+/
To quote ASRock:
You my friend are the real MVP. Haha thanks mate. :)
