Ok so I play Archage and there is a fishing bug with the boats causing unplayable lag which is ruining it for me. i found this video
https://www.youtube.com/watch?v=ohVQypcBIAI
It explains how to change the settings on Nvidia cards. When I go to the catalyst control centre it says many of the options but I can't seem to find the CUDA Gpus one which I need to change. What do I do to find this and fix it?
- thanks for the reply-what do i change to get it to work then?
only options i can see are:
anti-aliasing-mode, filter and samples
filter
Morphologiccal filtering
anisotropic filtering-mode and level
texture filtering quality
surface format optimisation
wait for vertical refresh
open gl triple buffering
tesselation mode
max tesselation mode
i see my knowledge of the game is irrelevant.,jus
to need work out cuda gps/firestorm settings
filter
tesselation mode
