Question Arctic Accelero Fan connection won't fit
Jul 27, 2019
My Arctic Accelero Xtreme iii has a 4 pin and 3 pin connection for the fans but my gpu only has a 6 pin and 2 pin port. Is there any way to fit the 4 pin on the 6 pin port and make it work?
helpstar
Illustrious
Jul 27, 2019
You will need something like this
https://www.arctic.ac/de_en/4-pin-adapter.html
or use the solution of this guy:
I just tried using the 4 pin adapter that came with it and the fans didn't work 😕 I guess the cooler is DOA.
