Hi, can anybody help.
I have a new system, Mobo Asus TUF Gaming Z690-Plus D4 with Arctic Freezer II 280
When I power on it it boot into BIOS as you would expect.
But it boots in 2 modes.
mode 1
The BIOS reports 24 - 26C for hours and the world is happy
mode 2
The BIOS CPU temp climb at a few degrees a second until I turn the power off before 80C
It seems randomly the Arcticv Freezer II pump is not starting as this is the only thing that could cause temps to rise a few degrees every second.
The coolers fans are running normally 1500 rpm.
I have even tried another Arctic Freezer II 240 and the same thing happens.
Anybody got any ideas ?.
Its connected to the AIO pump header, and set to PWM mode.
Is it the Power supply or maybe the mobo has a fault.
The fact that sometimes it stabilises at 25-26C for hours means the cooler is mounted correctly and doing its job.
mode 1
mode 2
