kamikazilucas Distinguished Nov 15, 2014 124 0 18,680 Aug 7, 2020 #1 i am using a arctic freezer pro 7 and the cpu runs way worse with it compared to a 120mm case fan with tape, but the problem is it keeps falling off, any suggestions for cpu fans that are good
Lutfij Titan Moderator Oct 7, 2009 54,048 4,741 173,390 Aug 7, 2020 #2 You will need to provide more information. What processor are you using? Also, if you're on any overclocks, what voltages are you dealing with? Best give us your full system's specs and then mention your airflow in the chassis. Reactions: Deleted member 2720853 Upvote 0 Downvote
