[SOLVED] Arctic Liquid Freezer II 240/280 with Fractal Design Define 7?
danvis
8
Hi all,
I've seen a review on youtube that says the Liquid Freezer II is an unusually big radiator that might not fit in all cases. From what I gathered online it's 63mm wide.
I want to pair it (probably mounted top) with Define 7 but I can't find anywhere what's the max width the define 7 will allow.
Anyone know for sure if it would fit?
Hi all,
The radiator is 38mm + fan 25mm = 63mm. The define 7 lists 76mm above the motherboard so it should work. Check here under specifications-
https://www.tomshardware.com/reviews/fractal-design-define-7
Hi all,
