Review Arctic Liquid Freezer II 240 Review: Quiet i9 Chiller
Zescion
Commendable
Oct 25, 2020
21
6
1,515
Nice cooler, but the Thermaltake Peerless Assassin beats it with similar noise using air and a third of the price.
shady28
412
281
19,090
Good to see this getting reviewed, most only do the 280mm version.
I've had mine for about 2 years now. It is a great AIO, punches well above its 240mm AIO class. Mine can keep up with sustained 220W loads without getting into thermal throttle. It's as good as it gets in this size class IMO.
Reactions: Why_Me
My baby!
I have it cooling my 5900X with the offset bracket/mod they have by default. It's only ~156W at full blast, but never goes above 70°C. Ah, this is also after installing the fix kit for the heatsink. It actually improved my temps by about 5°C, I'd like to say, but I never kept a close enough eye to gauge accurately, but I did see temps above 70°C before swapping it.
Also, you should let the CPUs run at full blast now. As long as you let them thermal throttle, it should be fine. You're just neglecting the most interesting data points for the cooler IMO.
Anyway, thanks as always for the review.
Regards.
Reactions: Albert.Thomas
So, what I'd REALLY like to know is how this cooler manages to not exceed the amperage requirements for a single PWM header when just one PWM cable is running both fans, the pump and the VRM pump as well? Do we have any specs available on what each of those contributory components draws in terms of peak amperage requirements. Normally we tell people not to put more than two or at most three fans on a single PWM header, and it seems like a pump plus another small fan is cutting it rather close.
From what I understand, the AIO_PUMP header in most motherboards has higher amp delivery precisely of that reason, plus it serves as monitoring for the pump itself for AIOs.
My Arctic Freezer uses that single connector, although I could connect the fans independently to the CPU_FAN headers.
Regards,
