Question arctic liquid freezer II 280 Phanteks p500a
Sep 24, 2021
Hi,
I am going to place liquid freezer II 280 in front mount push pull config and I am wondering whether it will fit if my gpu is rtx 3080 asus rog strix. I point out I'm not going to mount the gpu vertically and I'm not going to change my ming regarding it. Another question is how much of increase should I expect with push pull front mounted against pull front mounted - the radiator isn't that thick though. Has anyone had any experience with this kind of setup?
Phaaze88
Ambassador
http://phanteks.com/Eclipse-P500A.html (Gpu clearance: 435mm)
Gpu: 318.5mm
LF II: 38mm
with one fan: 63mm
with two fans: 88mm
435 - 318.5 - 88 = 28.5mm left over.
Didn't do it with that same AIO(Celsius S36), but nothing really changed Vs fans on just one side, and it's more of a pain to clean.
