Hello,
I have a few Arcting cooling fans (including the Cpu fan),
and they all connected to each other using their PST method.
and they are connected to the CPU PWM socket on the motherboard.
that way it control all the fans speed.
One of my fans (AF12025 PWM 120mm) started to make noise, so i purchased a new
fan of arcting cooling model : F12 PWM PST CO rev.2 .
When i wanted to connect my other fan (AF8025 PWM 80mm) to it i discovered that
the plugs don't fit to each other.
The F12 PWM PST CO rev.2 have a Male plug which is a little different,
making it impossible to connect the AF8025 PWM 80mm Female plug to it.
See the picture here:
How can it be? it's not something that is standard?
Do you think the fan came with the wrong Male 4 pin plug?
Thank you.
Thank you.
