Question Are 450w enough for my system?
Tenpu90
17
I have a PSU 28 months old
It is a Corsair CX450
The pc is
Gigabyte Aorus B450 M
Ryzen 5 5600 + fan with LED
Sapphire RX6600
Corsair Vengeance 2x8gb 3000Mhz
5 fans (3 with led)
wifi Archer T5E card (probably I'll remove that since I don't need anymore)
Crucial SSD M.2 1 TB
LED strip
I just updated it with the GPU, new CPU and adding fans and I'm wondering if I need to update my PSU that is only 450watt.
What do you think?
If I check online test site it should be ok, but I wanted be sure also because it is 28 months old. (mainly gaming use, but not so heavy because before i had integrated GPU)
How can I check my usage? I have OCCT, but I don't understand so much :(
Thank you
