[SOLVED] Are Addressable RGB Pins and Addressable LED Pins the same?
Aug 22, 2020
Looking for a mATX motherboard with an argb connector for the fans on the MB311l but I cant figure out if the connectors are the same.
Inside the MB311L ARGB case, there are SickleFlow 120 ARGB fans,
fan specs: https://www.coolermaster.com/catalog/coolers/case-fan/sickleflow-120-argb/
And what i can tell, the ARGB connector on the fan isn't proprietary. Instead, it is the standard ARGB connector, which is the same ARGB found on MoBos that have ARGB pins.
ARGB pinout:
pin #1 - +5V
pin #2 - data
pin #3 - empty (no pin)
pin #4 - ground
