Lycaone Distinguished Mar 2, 2017 129 0 18,690 Sep 24, 2017 #1 Is it possible to change the Corsair H100i v2 fans with Corsair HD120 RGB fans ?
Solution C C ccampy Sep 24, 2017 Yes they are just standard fans you should be able to use any other 120 mm fan
C ccampy Honorable Jan 4, 2014 1,052 0 11,460 Sep 24, 2017 Solution #2 Yes they are just standard fans you should be able to use any other 120 mm fan Upvote 0 Downvote Solution
