L LegendOfLich-1382235 Honorable Aug 6, 2013 97 0 10,640 Mar 16, 2014 #1 Are all the parts in this build compatible???? http://pcpartpicker.com/user/LegendOfLich/saved/44Nw
Solution RazerZ Mar 16, 2014 Yes but switch the ram for this one: http://pcpartpicker.com/part/a-data-memory-ax3u1866w4g10dgv ( faster ram and its cheaper) Edit: ok woltej1 I'm on board now And for $50 i'm sure there are better cases avialable.
RazerZ Judicious Ambassador Aug 18, 2013 9,961 0 33,960 Mar 16, 2014 Solution #2 Yes but switch the ram for this one: http://pcpartpicker.com/part/a-data-memory-ax3u1866w4g10dgv ( faster ram and its cheaper) Edit: ok woltej1 I'm on board now And for $50 i'm sure there are better cases avialable. Upvote 0 Downvote Solution
woltej1 Splendid Nov 15, 2010 3,534 1 24,960 Mar 17, 2014 #3 everything seems fine, don't worry about getting the xfx, not worth the money and you aren't getting much in return, 430 is plenty to power that system. Upvote 0 Downvote
tiny voices Titan Sep 6, 2012 34,175 5 99,965 Mar 17, 2014 #4 Definitely agree with the RAM suggestion. The PSU is fine as long as you do not plan to upgrade the CPU. The cx430 is Seasonic based unlike the rest of the CX line, so it is good. Upvote 0 Downvote
woltej1 Splendid Nov 15, 2010 3,534 1 24,960 Mar 17, 2014 #5 tiny voices : Definitely agree with the RAM suggestion. The PSU is fine as long as you do not plan to upgrade the CPU. The cx430 is Seasonic based unlike the rest of the CX line, so it is good. it was actually the 400W cx that was made by seasonic, but that was discontinued. The 430 is still a great psu though. Upvote 0 Downvote
tiny voices Titan Sep 6, 2012 34,175 5 99,965 Mar 17, 2014 #6 This is correct. The cx430 is by far the best of the CX line though. Upvote 0 Downvote
