Are all these parts compatible with each other?
DemonicCreature
13
Hi, so I thought of building a pc and decided on the parts. Just wanted to know if all these parts are compatible with each other
Ryzen 5 1600
MSI B350M gaming pro
Crucial Ballistix Elite 8GB 3000 MHz
Zotac GTX 1060 6GB Amp edition
Antec VP600P PSU
Corsair SPEC 02
WD Blue 1 TB
Also I have a monitor that has a VGA connector and since the graphic card doesn't come with one I will buy a VGA to HDMI cable. So, during the first boot into BIOS do I connect the video cable into the graphic card or the Motherboard?
If it's all you can afford then it'll have to do. There are some moden titles it'll hurt you a bit, but nothing drastic today. Can always add more later if needed
I thought that 8GB was the perfect memory size for a gaming pc if you don't use any other demanding software in the background. I won't do any editing or recording gameplay stuff, so 8GB should be fine right because there is a 100$ price difference here in India b/w the 8 GB and 16GB stick
Thanks for helping out!
Appreciate it.
