[SOLVED] Are B550 Aorus Pro or B550 Aorus elite Asus Aura sync compatible?
khangnt2005
75
I am looking to upgrade my system to Ryzen 5000 and B550 motherboards. Are those motherboards mentioned in the title Asus Aura sync compatible? Asus B550F motherboards are 50 - 100$ more expensive than the Aorus ones in my place.
I'd say: No.
Gigabyte RGB Fusion 2.0 is different from Asus Aura Sync. And it's different from MSI Mystic Light and ASRock Polychrome Sync.
So, if you have a product that supports Asus Aura Sync but does not support Gigabyte RGB Fusion 2.0, then you can control that product only with Aura Sync.
Aeacus
Ambassador
I'd say: No.
Reactions: khangnt2005
