Question Are Connecting Sockets Easy?
Oasis Curator
263
8
10,695
I plan to run a network cable from downstairs inside, to outside, up the side of the house and into the loft. I already have a route plan for it. The run will be around 25m (worst case).
Not really a feasible route inside the house. I did have a potential to run it inside the house but the logistics of doing so is just too great.
However, I'll have to cut one plug off the end of the cable to fit through the hole in the side of the house.
Are wiring up sockets easy? I guess on the wall, I'll have to put one and connect the wires to it, then have another wire go from the socket to a switch for net access.
Either that or drill a much larger hole to push the RJ45 connector through - not ideal.
Do I need any special tools?
What you want is a tool-less keystone jack for the wall, which snaps into a faceplate. The tool-less jack will press the wires into the copper taps for you, otherwise you'd have to use a punchdown tool or very thin screwdriver which is harder. Make sure the jack is the same category as the cable you'll be using, Cat5e, Cat6, or Cat6A because the thickness of the individual wires matters. Cat6 is kind of a pain but may as well future-proof. You can find videos and articles easily to show how to put the wires in.
https://www.amazon.com/AMPCOM-Keystone-Tool-Less-Punch-Down-Required/dp/B0CY881VR1
You could also buy a regular keystone jack and a punchdown tool if you wanted to learn how it's usually done. Tool-less jacks cost more than regular ones so in volume you wouldn't want to use them.
The plate of course is designed to be screwed into a receptacle box, but you can screw it directly into drywall and just don't beat on it too much and rip out the screws. Leave yourself plenty of extra cable that you can coil up inside the wall in case you ever need to snip some off to rewire it (like a few feet, or even several if you might want to move it to another area of the wall).
If the downstairs end is in a living room or something, I would put wall jacks at both ends for convenience, so you can just unplug the cables if you ever need to for any reason, instead of permanently having a bunch of cable hanging out of the wall. If it's in a basement or utility room with a bunch of other wires then that may not matter.
As long as you know the wiring code not a big deal but although I have did many I also will admit I have had a lot of do overs.
My eyes just can't see them small wires to the channels in the end piece for crimping unless I'm in the shop with a desk mounted boom magnifier lamp. The crimping tool are $25 on up for better crimpers.
I have also drilled the hole larger and so easy to fluff patch back up after wire is where you need to run it. On the inside drywall a little drywall mud on your finger will patch that and on the outside wall silicone to seal the hole.
I have had to do it this way on rentals in the past to when you leave remove the wire, a quick patch on both sides of the wall and it was never there. A cable installer I watched did that as well drill, fish the wire than patch the same as I did..
You can also keep the end piece on the wire and not cut it off. I have a file that when fishing the wire thru the hole I adjust the hole just big enough so I can pull the wire taped to a long 3 foot screwdriver and guild it on in.
Something to keep in mind here. Unless you are routing this behind your siding you will need to get outdoor/sunlight rated wire. The sun will mess up a regular cable in quick order.
edit- I would put it in pipe, personally
Reactions: stonecarver
Practice
Practice
Practice
Buy a bunch of extra RJ-45 ends.
Cut several 1 foot long pieces.
Practice.
Test with an inexpensive tester.
You do NOT want your first attempts to be after snaking it through the wall, and then seeing that you failed.
Or as above, tool less keystones.
Still, practice!
Reactions: stuff and nonesense
OP, if you house has vinyl siding you could run the wire behind it and/or use the corner molding to run the wire out of the sun. There is a tool called a "zipper" that will make putting the pieces back easy. I would warn not to do so if it is very cold outside or if the vinyl is very old. It gets brittle under those conditions.
Assume that every outdoor pipe, no matter how well constructed and attached, will eventually get water in.
I stand behind my statement. Aside from that, if you do 'think' there is a possibility of water getting in then it calls for a different type of cable altogether. "Direct burial" which is not in line with the UV protected kind suggested. If it is inside the proper PVC and fitted correctly, then normal plenum rated cable will be fine.
I’m not sure about US wiring but.. I used a pair of power line network adapters to get internet up the stairs in my home without major problems. I reset them once a month. After I saw one was locking every 2 months. 30 seconds off per month was enough to have no faults while I wanted to use it. No work needed, no cable to run..
Yes.
Generally, powerline adapters would work.
The male connectors are a pain to make especially the CAT6a, but the female ones (for the wall outlets) are very easy. It's almost impossible to do it wrong unless you are colorblind or something. I personally bought a 60$ kit at Lowes to make them but the tool-less ones should do the job too (but you still gonna need a tool to strip off the cable to take out the wires).
I tried these, albeit very slow ones (I'm in the UK too!).
Routing a flat network cable (yeah, yeah, I know) through the house gave me a huge speed increase over the powerlines.
We're in an even older house now so I don't hold much hope in the wiring.
The routing will be going from a switch downstairs to a TP-Link Deco upstairs, although might just be direct to the PC upstairs as I get good signal upstairs from the Deco downstairs.
It's whether I terminate it in a socket upstairs and run another cable from there to the PC, or have enough to just pull through and plug direct to the PC.
Will see as I'm doing it.
Complicated though as this will be in conjunction to changing the location of my TV ariel, which is currently in the loft. There is an old one on the roof, but I have a newer one with bracket and everything. Plan is to get the ariel cable out the loft and use the one on the roof, then use that same hole to route the CAT6 in, through the loft to the back room, where the Office will be.
I think I'll try and wire a socket (possibly two) and see how that goes. If it isn't working, I'll go with Plan B.
Sort of a side discussion to say that I picked up some of those TP Link Deco to use at my mother's house. They were on a great price and even with the shortcomings of the model I selected, her internet speed and use case wasn't going to cause issue with their "real" link speed. It did a well enough job alongside some infrastructure changes her ISP made in the area that she can, for the first time, actually stream a video while sitting in her favorite chair.
