H HerEyeSin Reputable Feb 19, 2019 209 2 4,685 Mar 6, 2019 #1 what title says, would also like to know if ring plus are ARGB
Solution ayazam Mar 6, 2019 this is a CPUs forum, not PC's part u should go to component or cooling forum to get the right answer anyway, both fans are RGB
ayazam Distinguished Jun 22, 2013 43 2 18,545 Mar 6, 2019 Solution #2 this is a CPUs forum, not PC's part u should go to component or cooling forum to get the right answer anyway, both fans are RGB Upvote 0 Downvote Solution
popatim Titan Moderator Dec 2, 2009 38,904 980 135,890 Mar 6, 2019 #4 This has been moved from CPU's. Thank you. Upvote 0 Downvote
