Recently I'm experiencing a lot of problems with my system (windows 10 running on an SSD drive) and I'm on the trail of a failing data HD (internal 2TB), but not sure about this.
I've searched for ways to check my drive's health, but all simple tests say all is good. I've run a scan with HDDScan, but that doesn't really help me further. Am I searching in the wrong place or can anyone give me some advice on how to check my HD?
Thanks a lot!
- Some torrents gave the "redundancy check error" after being 100% finished in Utorrent
- Explorer often crashes when transferring data
- When I try moving some data to an external HD, sometimes it just stops in the process or transfers at a few kb/sec
- Movies that are on my HD hang/freeze when I play them and when I reboot my system, the problems are gone for a bit, but not long
- When the system doesn't run smooth or explorer crashes, my HD makes a humming noise
Thanks a lot!
